Ga door naar hoofdinhoud
Touch not working after screen repair
Fixing a friends Pixel 2 XL, had a cracked screen with no touch so I replaced the screen with an original graded screen and the touch still doesn't work. Tried a factory reset but still nothing, does anybody have any ideas?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
First,many screens sold as original or oem are fake. They are genetics and the sellers on eBay or amazon lie.
This doesn’t mean it won’t work.
Did you disconnect the battery prior to repair? You ALWAYS want to disconnect it first. If not,when you connect a screen,it can short high voltage lines to low voltage lines if you connect it at a slight angle…the pins may go on cockeyed at first,for a split second shorting voltage. This can cause a quick surge(like a punch to the face) of electricity to damage components.
Have you taken it back apart? Did the old screen still work with Touch? If so,you should try it to rule out. If it stopped working at all after being cracked,the first thing to do is try a new screen…that is,as long as you have taken it back apart and disconnected and reconnected the screen to make sure it wasn’t a bad or loose connection.
Was dit antwoord nuttig?
1 Opmerking:
It's definitely an original screen, I connected with the battery disconnected.
door
I dropped and cracked my Pixel 2XL as well, and my phone seems to be functioning just fine but touch won’t work. Did you ever get your friend’s pixel 2xl working? I miss mine so much :(
Voeg je antwoord toe
David F zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 1,226
