Ga door naar hoofdinhoud
De eerste generatie Nvidia Shield Tablet uitgebracht in juli 2014.Deze tablet wordt veelal gebruikt door gamer, en heeft zowel WI-FI als LTE mogelijkheden.
24 Vragen Bekijk alle
I wiped my hard drive by mistake
would that get me access to the tablet again ? currently i cant access it as i wiped it and cant recover it. Or will replacing the mother board do nothing and put me in the same boat im currently in now -with having to reinstall the OS ?
Is dit een goede vraag?
4 opmerkingen:
is the recovery partition still on the device?
door
no sadly i wiped it :(
door
Yes by replacing it you be running again
door
My next question is replace the motherboard or trying to flash the current one that has been wiped ? I mean there must be a way to flash it..no? They do it at the plant I literally have a clean slate hd/motherboard there must be a way to flash it ...if I can't is the original Motjerboard 2015 shield the same is the shield k1 version circa 2017
door
Voeg een opmerking toe
1 Antwoord
Start with this in fastboot mode:
https://twrp.me/nvidia/nvidiahshieldtabl...
Flash the TWRP - then you can search XDA to get a ROM to flash https://forum.xda-developers.com/shield-...
https://wiki.lineageos.org/devices/shiel...
Recovery: With the device powered off, hold Volume Down and tap Power, then release once menu is displayed. Tap Volume Down until recovery is selected. Press Power to select.
Download: With the device powered off, hold Volume Down and tap Power, then release once menu is displayed.
Was dit antwoord nuttig?
Voeg je antwoord toe
Andrew Brown zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 176
