Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
20 Vragen Bekijk alle
White lines on the display and still after replacement
I had an iPhone 5 that was working properly, but I dropped and it cracked the display and started to show white lines on the display (
) so I replaced the display and it still show the lines (
) so I tested the new display on another board and it works normally (
), what could it be the issue?
when the screen first light up you can't see nothing on the display, just white, but if you wait a bit it starts to get better, but the lines still visible.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
It’s most likely a bad lcd connector on the logicboard. It will need to be replaced by a professional micro-solderer
Was dit antwoord nuttig?
Voeg je antwoord toe
Heitor Scatolin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 35
