Ga door naar hoofdinhoud
Repair information for Bosch dishwashers.
39 Vragen Bekijk alle
Will not drain at end of cycle
My  Bosh  dishwasher has been a problem and will not drain at end of cycle I cleared all lines, not solved then replaced the pump, not solved  then replaced the pressure sensor, not solved them replaced the motherboard, not solved detached the long part f the drain hose and redirected the short half to drain into a pail, bravo worked then raised the pail and stopped draining again. Seems that any back pressure  causes a E25 and will not drain. Can anyone help?
Is dit een goede vraag?
3 opmerkingen
Has it ever worked correctly? Have you changed your disposal lately?
door
Worked fine for 4 years and we have no garbage disposal. Thanks for looking in.
door
Have you checked the float at the bottom of the dishwasher make sure nothing is under it?
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
It seems that when pump rotation is not entirely blocked but only obstructed, E25 is signaled only on end drain cycle and not on other drains between washing program.
The control board circuitry measure pump electric current load and when exceeded for any reason, it signals E25.
In my case blockage was built from bucket of fibers and/or hairs around steel axis just under impeller caused pump motor needed more power to turn and escalated current.
I couldn’t even imagine how many fibers manage winded around steel pump axis in 7 years and breaking rotation and escalating pump electric current load.
I remove pump after opening down front of dishwasher. After pull impeller together with fix magnet rotor and rotor cover from pump. Then carefully clean axis between impeller and front rotor cover with forceps in small sharp knife.
Was dit antwoord nuttig?
Score 2
That was exactly what I thought after having the same problem. Thanks for the reaffirmation of my Sherlock thought process. I'll look up pump, impeller access..
Voeg je antwoord toe
David zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 21
Altijd: 1,972
