Ga door naar hoofdinhoud
Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
124 Vragen Bekijk alle
Can you change your screen glass type
I have the Apple Watch series 4 with the aluminum case with the ion x glass screen and it broke so can I buy the sapphire screen instead because it is claimed stronger and only 20 differences
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Well… Its not that simple!
First a Sapphire display is not as easy to see as it has a bit more refraction.
As far as being stronger not really! It is easier to fracture! Just less likely to get scratched.
I would strongly recommend you stick with the Ion glass. When I was fixing Apple Watches (series 0, 1 & 2) I saw more broken Sapphire displays than the Ion. I had one customer who in less than two weeks broken his display again dropping in on to a concrete floor. The third display he went with the Ion glass ;-}
iFixit currently does not sell the Series 4 display, you’ll need to try to locate a source for the display. You will need to transfer the NFC chip to your new display. Otherwise you’ll need to go to Apple to get your watch fixed.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Drew Brown zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 88
