Ga door naar hoofdinhoud
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 Vragen Bekijk alle
USB Adaptor for SSD -MacBook Pro 15 retina Mid 2014
Hi All
my Macbook is not turning on.I Have tried to reboot it by holding CTRL,SHIFT,Option power button.But nothing happens.
So before trying anything to take backup i have remove ssd from Mac.
But I am not sure to choose USB Adaptor so that I can connect to drive to another Mac and copy the data.
https://eshop.macsales.com/item/OWC/MAU3...
above adaptor bit costly for me, Is there any other simple adaptor available for cheap.
If yes can provide links plz.
Attached the image of ssd
Also any suggestion to check further to the turn on the Mac which is not turning on?
Thanks in Advance
Thambi
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Any adapter marketed for a Macbook Pro/Air 12+16 pins will do, you maybe be able to find something cheaper for a casual use on bigger marketplaces like Amazon or eBay. Try disconnecting the battery of your Mac and plug in the Magsafe, it should boot on its own. If it doesn’t first thing to rule out is a possible failing charger, so either you can borrow an alternative Magsafe or you’ll need to test its power outlet with a multimeter. If it does, try a battery replacement.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Can you give me link for the same?
door
I'm in EU, thus you might be redirected to a different URL, but this would be a somewhat cheaper alternative: https://www.ebay.it/itm/12-16-pin-Micro-...
In case you have troubles google this string "macbook 12 16 pin usb adapter"
door
Thanks for the link. I though I could get something less that $50.
So the cheapest around $80 :-)
Before removing the ssd I disconnected the battery and connected the charger but MAC still didn’t tun on and also tried with two charger before. So am not sure what to do further
door
@aasay OWC has used ones for about $58. They carry a warranty but you need to chat with them and get them to give you the link. After you have recovered your data, you can resell it on eBay and make $20.
Score 2
1 Opmerking:
Let me try that option too
Thanks @mayer
door
Voeg je antwoord toe
thambi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 81
