Ga door naar hoofdinhoud
Uitgebracht op 26 oktober 2018. Modellen A1984, A2105, A2105, A2106, A2108. Verkrijgbaar als GSM of CDMA / eSIM, nano-SIM of dual-SIM / 64, 128, of 256 GB / Zwart, Wit, Blauw, Geel, Koraal of Rood. (Uitgesproken "iPhone 10 R.")
How to shut off iPhone XR with a broken screen
So I was trying to replace my broken screen, and in the process I accidentally broke it further. No big deal I thought, since i’m replacing it anyway. Then before I got all the adhesive off, I accidentally turned it on. Is there a way to either shut it off without the screen or safely disconnect the battery? Or do I have to wait for the phone to die
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Press vol up, then volume down then press and hold power button.
Do this until you see the screen go off, then on again then off. Usually this makes the phone stay off without itself turning on again.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
this dosent work it turns back on in minuntes, esentally restarteding the phone
door
So it’s actually to press up down and hold power button until screen shuts down, and then push up and power together and hold until it shuts down again and there you go!
Voeg je antwoord toe
Christian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 49
Altijd: 22,615
