Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Grand Prix kreeg in 2004 een update op een herziene versie van het GM W-platform en werd op 7 februari 2002 op de Chicago International Auto Show onthuld als de Grand Prix G-Force Concept.
Why is my car dying while I am driving down the road?
As I am driving down the road my car will just die. I lose power steering and power brakes. Once I pull over it will turn back over and start. Sometimes it sounds like the starter might be sticking when I try to turn it over to start. So I'll know it wont run right if it does that and I will turn it back off. Eventually it will start again but may die at any time driving.
Is dit een goede vraag?
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Het nuttigste antwoord
This sounds like a failing or corroded electrical connection. Take it in to a auto parts store that offer free computer read out to help with the diagnostic. AutoZone is one that does it.
Was dit antwoord nuttig?
Score 2
Could be dirty fuel
When was the last time it was serviced ??
It may need a service filters , oil etc
2 opmerkingen:
I use the middle grade of gas. Sometimes when you try to restart it, it sounds like the starter maybe sticks a little. When it does this I have to turn it back off because I know it will die again while driving.
door Deel
The starter is there to start the car After that it does not come into play at all
It would have nothing to do with the car stopping
It may be the started is stuck
A service by a mechanic I be thinking will solve this issue and ask him/her to inspect the starter
You should get it serviced because block air filter could easly cause the issues you are having and that means not starting or very difficult to start
The engine is not getting enought air throught the air filter
It could also be the injector plugs
door Deel
There is a recall for the ignition turning off while driving it.
I've had the throttle body, gas pedal, gas tank, fuel pump, sparkplugs, map sensor, ground wire all replaced & it still says reduced engine power light comes on after a few minutes of driving
1 Opmerking:
@peggyklitz25048 any codes when you scan the OBDII?
door Deel
Voeg je antwoord toe
juliestokes31035 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 930
