Ga door naar hoofdinhoud
Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
678 Vragen Bekijk alle
Vibration doesnt work accept home button
Vibration is only working in home button feedback but not in other cases like the system wide haptic feedback or vibration on ringtone.
i severely broke my phone & had to change the casing by placing my motherboard onto another iphone 8 plus casing which was icloud locked.
After that I’m facing 4 problems
  1. Haptic feedback works only on home button (tried changing setting and restore iphone)
# No airpod prompt when I open the lid, cant connect it instantly, gets disconnected often
  1. low wifi range
  2. Most often only 2 bars in cellular network indicator.
  3. can anyone suggest me a fix?
  4. thanks in advance
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
  1. low wifi range
These two more then likely caused by incorrect assemble of the antennas
you need to back track on your work
iPhone 8 Plus flexkabel van de diversiteitsantenne
Was dit antwoord nuttig?
1 Opmerking:
Thanks @edigitcom
And about taptic feedback?
door
Swap the vibrator over so its using the original.
Voeg je antwoord toe
Nazmul Hossain zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 314
