Ga door naar hoofdinhoud
2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
759 Vragen Bekijk alle
upgrade MacBook Prod HD and ram
Apple MacBook Pro "Core 2 Duo" 2.4 15" (SR) Specs
Identifiers: Mid/Late 2007, 2.4/2.2GHz* - MA896LL - MacBookPro3,1 - A1226 - 2136
MacBook Pro 15 2.4 intel core duo 2GB
hi
I plan to upgrade my macbook pro HD from 160 GB to highest one. which the highest one I can buy? can pls provide the link for amazon because im confuse from long time
And also I want upgrade the ram to 8 GB?
Pls advise..
Is dit een goede vraag?
Score -1
2 opmerkingen
Please give us the last three figures of your serial number so we know exactly which machine you have. There are different 2.4 15" machines
door
The last three figures of serial number: XAG.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Here's the link you requested from rj, he is correct: http://www.everymac.com/systems/apple/ma...
Here's a link to hard drives that will work for you and fit in your machine, the largest is a 750 GB
http://www.ifixit.com/Mac-Parts/MacBook-...
Was dit antwoord nuttig?
Score 1
You can put up to 4GB of DDR2 667MHz memory, and the hard drive you can use up to a 250GB drive under most circumstances.
Score -1
10 opmerkingen:
I downvoted you because you gave an answer before we know the facts of which machine Boudi has. Some will take up to 8 GBs of memory. The earlier models of the 2.4 will take a 750 GB 9.5 mm, the later Unibodies will handle a 1 TB 12.5 mm, this is from OWC, "1.0TB WD Scorpio Blue 5200RPM SATA *12.5mm* HD with Advanced Format Technology - Fits all Apple MacBook/MacBook Pro 'Unibody' Models (13/15/17"), MacBook Pro 'pre-unibody' 17"
door
I think my is earlier one. For the memory do u meen that I can't put 8 GB DDR3? For the HD can you pls help me to find it in here and from amazon?
door
According to your serial number Apple says your computer will take 4 GB but OWC says it will take 6 GB. I don't believe your unit will work with 8 GB--the max would be 6 GB of 667 MHz PC2-5300 DDR2 SDRAM.
door
can u pls provide me the links for this ram 6 GB and also HD to buy them
pls..
door
5 commentaren meer tonen
Voeg je antwoord toe
Boudi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 6,457
