Why is my Sportster wet
Plugs are dry but exhaust is wet. Has a bad exhaust leak on the cylinder in question
1998 XLH 883/1200. Sportster
Thanks. JC
Is dit een goede vraag?
Thanks. JC
Jackie, water is a byproduct of combustion. Look at the tailpipe of almost any running engine; it’ll be dripping.
Was dit antwoord nuttig?
Hello Doug I believe in this case it goes a little deeper than condensation. The Sportster has a really bad miss it's had new heads and pistons installed recently by someone whom I'm wondering if they knew what they were doing. It had a exhaust manifold bolt missing and a big gap between the flange and the head that has to be a tight fit. It's not. So I believe it may have valve damage exhaust side. I currently have the jug/ head removed. A big pile of carbon surrounding that valve.
Stem. Also I'm inspecting the carb exccelarator pump ..
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 20
Altijd: 89
