Ga door naar hoofdinhoud
Smart fitness watch via Bluetooth, released in March 2016. Model: FB502SBUL
20 Vragen Bekijk alle
Why is my blaze on constant vibrate
My Blaze is constantly on vibrate. It happened in the middle of the night and will not stop.I put it on the charger and it is still vibrating
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Alvaro, the Fitbit Community Manager, suggests performing these steps:
Try restarting your tracker by doing the following:
Press and hold the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen. This should take less than 10 seconds. Then, let go of the buttons.
If your tracker doesn’t work normally, turn off your tracker manually by performing these additional steps:
  1. Swipe right to left on the home screen to the Settings screen.
  2. Tap Settings and scroll down to Shutdown.
  3. Tap Shutdown and confirm.
  4. To turn your Blaze back on, press any button.
  5. Sync your tracker as soon as you turn it back on. If you don't, the time may be incorrect.
Try this 3 times in a row.
Also if you have any alarms please deactivate them and sync your tracker.
If that doesn’t fix the issue, then they ask that you contact Fitbit Support here.
Was dit antwoord nuttig?
Buttons aren’t working either. Worst watch ever.
Voeg je antwoord toe
Deb Robertson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 861
