Ga door naar hoofdinhoud
The Asus X200CA laptop is 11.6 inches and weighs 2.6 lbs. It comes with a either an Intel® Core™ i3 3217U Processor, an Intel® ULV Pentium® 2117U Processor, or an Intel® Celeron® 1007U Processor, 2 GB or 4 GB of RAM, 320 GB to 1 TB of storage, Windows 8 OS, HD webcam, and an estimated battery life of 3 hours.
7 Vragen Bekijk alle
Screen is black, computer runs
I had tried a lot of methods I’ve read, for example the ones where I need to remove the battery and hold the power button for several seconds, even minutes, also the F2 + power button and there’s still no response. I was able to connected to my TV. I read somewhere about going to system manager and deactivate the intel graphics. I did that and then i activated them again and I was able to see both screens. I unplugged the Tv did some work on my computer then turn it off. The next day, I turned the computer back on, and was the screen again black, I repeated the method, and it worked. I just feel unnecessary to repeat this process over and over again, does anyone has an idea what do I need to do
Is dit een goede vraag?
1 Opmerking:
Are you remembering to save your changes if appropriate? Might also want to check your users manual to see if there is a function key toggle for switching between external and internal monitors.
door
Voeg een opmerking toe
1 Antwoord
If you can get a display signal to your TV then I’m pretty sure the laptop screen is almost completely dead.
Was dit antwoord nuttig?
Voeg je antwoord toe
Javier Portillo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 118
