Ga door naar hoofdinhoud
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
125 Vragen Bekijk alle
Charger Port Replacement and pulled Pads
Tried to replace a iPad air charger port, Pulled 3 pads however, Pads 3,9 and 27
soldered new port in iPad still charges, pads 3,9 & 27 are ground pads
1.) should these ground pads be connected using jumper wires? im at a loss to where to connect them
if No
does this not make the circuit open, and is it safe?
Is dit een goede vraag?
3 opmerkingen:
I agree with @propman , ground is there for a reason and most sensitive rails may suffer a lack of grounding. Choose the closest grounding spots you can find with your multimeter and make a couple of bridges to be on the safe side.
door
@propman i was thinking the same too!
door
@arbaman i haven't tested data transfer as of yet, i will try this and post what happens
door
Voeg een opmerking toe
1 Antwoord
Never hand my hands on one of these rascals, so please take my comments with a grain of salt if you want. :-) Your unit maybe charging OK but does the connector also handle any data lines; the ground connections may come into play then if it does. For example when transferring files back and forth between a computer and your tablet. Just a thought......
Was dit antwoord nuttig?
Voeg je antwoord toe
Eli Villie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 194
