Ga door naar hoofdinhoud
The Dell XPS 15-L502X laptop was manufactured by Dell Inc. It was released in 2011 with a 2nd Gen Intel® Core™ processor.
Laptop occasionally turns on
When I press the power button, only the fan turns on. One out of 10 tries, laptop turns on.
Is dit een goede vraag?
1 Opmerking:
Couple of possible suggestions at:
Dell XPS 15-L502X Troubleshooting
Besides that, it's a matter of opening up the unit and doing visual inspection, voltage measurements etc
door
Voeg een opmerking toe
1 Antwoord
A short, might preventing the board from starting. Check the standoffs between case and board and make sure that the case fans are connected to the motherboard only, not to both motherboard and power supply.
Tips:
As long as the power supply did not damage the hard drive control board all the files should be fine. But do remember, back up you computer is a good way to prevent loss caused by any unexpected.
Was dit antwoord nuttig?
Voeg je antwoord toe
Subodh Bansal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 84
