Ga door naar hoofdinhoud
Uitgekomen op 4 november 2017. Model A1865, A1901. Verkrijgbaar als GSM of CDMA / 64 of 256 GB / Zilver of Space Gray. (Uitgesproken als "iPhone 10".)
1199 Vragen Bekijk alle
Help with problem detection - Rebooting after frame replacement
Hi, I have bad bluetooth, cellular and wifi signal. I bought Frame with few parts installed (buttons, bottom part -> taptic engine, speaker, 2 flex cables). When i put my motherbards and remaining parts into new frame phone starts noramlly but after 1-2 minutes of using it will reboot iteslf, and when it will turn on it will ask passowrd for the first unlock (not face id) as it should after reboot, but it wont ask SIM pin code, sim will unlock automatically withou pin. I switched few parts and problem can be only in frame itself, buttons (complete buttons with flex cable) and flex cable that have attached lightning port. What do you think? Which part is causing reboot problem? (i will go today on holiday and i need working phone, so i dont want to keep disassembling and assembling it to prevent damge).
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I would start trouble shooting by disconnecting each flex in turn until the problem is resolved then replace the faulty part.
Was dit antwoord nuttig?
Voeg je antwoord toe
Johny zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 36
