Ga door naar hoofdinhoud
The first-generation Trooper was available as a three- or five-door wagon with independent front suspension.
2 Vragen Bekijk alle
Where do my heater hoses run of my thermostat housing and
I just got a 1989 trooper and the person I got it from started to replace the heater hoses. Theres one that comes off the thermostat housing and then.theres one under the intake manifold. So if you had any kind of a diagram of the heater hoses or any ideas where they go .?
Update (08/16/2019)
Its 4 cylinder 2.3 I think
Is dit een goede vraag?
1 Opmerking
Might want to check your library to see if they carry Chilton's and/or Haynes Automotive repair manuals.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Typically the hoses are two different sizes, each one should route to the heater core on the firewall. If you let us know what engine size your Trooper has I can try to find a specific diagram.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Chad Jackson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 264
