Ga door naar hoofdinhoud
Reparatie-informatie voor grafische tablets. Grafische tablets worden ook wel digitaliseerders, tekentablets, tekenblokken, digitale tekentablets, pentablets of digitale tekenborden genoemd.
huion 1060 pro won't turn on
i just dropped my tablet and i’m worried i totally broke it. it won’t respond at all. the led light wont turn on, none of the keys register, the pen doesn’t register, and it doesn’t show up as being connected to my computer.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Sounds like the unit’s housing probably needs to be opened up and the interior inspected for damage, loose connections, cold solder joints that have cracked due to the shock of dropping it, etc. If it’s under warranty you could try claiming a repair but more than likely if there is any indication it’s been dropped, the manufacturer will not cover the repair. If you are interested in trying to repair the unit yourself you may need initially some form of “spudger” tool(s) to open the unit. This site and others like Amazon have kits, such as the following, which can be purchased.
Essential Electronics Toolkit
That all said and done, you may find it is easier and more economical in the long run to just buy a new unit. Wish I could be of more help.
Our gateway kit to electronics repair, perfectly sized and priced for essential electronics repair. Afbeelding
Product
$29.95
Was dit antwoord nuttig?
Voeg je antwoord toe
Catlyn Leonard zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 988
