Ga door naar hoofdinhoud
{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
276 Vragen Bekijk alle
Why won’t my laptop charge?
My laptop shut down (low battery) and when I try to charge it (tried to wait for 30 min) it only shows the low battery screen with the connect to power symbol. Charger kept sparkling when put into socket, plastic not melted but metal prongs slightly melted (edge part a bit rough). Is the problem with my charger?
Is dit een goede vraag?
1 Opmerking:
Are you using the original charger and USB-C cable that came with your system?
door
Voeg een opmerking toe
1 Antwoord
Hello,
I’d advice you to try to use a different charger and see what happens. Meanwhile, try to move the charger adapter around and see if it starts to charge it. If you get the computer to start charging try to do SMC reset and PRAM reset and let us know what happens.
Cheers!
Was dit antwoord nuttig?
Voeg je antwoord toe
bianca zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 66
