Ga door naar hoofdinhoud
A simple and cheap laptop by Lenovo. This laptop can be seen in many K-12 classrooms.
9 Vragen Bekijk alle
Need help Unmanaging a chromebook
I bought a used chromebook off eBay and it is enrolled in some school thing i tryed to access dev mode by removing battery and plugging ac cord in multiple times but it still says admin blocked. And I don’t know if theres anyway to reset the bios can any of you help me
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
To Wipe your Chromebook follow these steps
  1. Turn off the Chromebook.
  2. Press Esc++Power.
A yellow exclamation point (!) or "Please insert a recovery USB stick" is displayed.
  1. Press Ctrl+D to begin Developer mode, then press Enter.
  2. Press Space, then press Enter.
The Chromebook deletes its local data, returning to its initial state. This can take approximately 40 minutes.
Note: ​If Forced re-enrollment is enabled for the device, you'll see a note that Developer mode is blocked. This shortens the wipe process, and still allows for re-enrollment when the device automatically restarts in Verified mode.
  1. When the transition completes, press the space bar, then press Enter to return to Verified mode.
  2. Enroll the Chromebook before signing in to it.
Was dit antwoord nuttig?
2 opmerkingen:
That’s the problem I’m trying to change the forced enrollment by changing the rw_vpd in dev mode but it’s blocked so what can I do
door
Have the same problem, bought a set on bankruptcy auction. They are locked and the old company is no more. 😟
door
Voeg je antwoord toe
Caleb zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 870
