Ga door naar hoofdinhoud
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
83 Vragen Bekijk alle
My ti-84 plus ce turns off on bright white screen?
I cannot find my problem anywhere in the forums
when i turn it off it shows blank bright white screen
My Texas instrument calculator TI-84 plus CE Works excellent except for when you turn it off it goes off on a blank white screen .
when you turn it on it goes on normally however, when it is on you cannot adjust the contrast or the brightness of the screen, you cannot dim it or even make it more brighter .
please take note that all buttons are functioning properly
and I have tried everything
hard reset pressing second delete and back reset button
also trying to reinstall OS didn't work
also try to clear memory several times same thing
remove the battery for more than 10 minutes then put it back same thing
also try the self test the brightness indicator changes values on the screen but still do not dim or brighten
please advise urgent thank you
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
White screen takes the most power to operate/. Might need a new battery
Was dit antwoord nuttig?
3 opmerkingen:
No, battery charges fine and it will take three to four days to die out that means the battery is very well charging and has a working performance anyhow I tried another battery that's working excellent in a different no problem calculator and still have the same problem
door
door
I really appreciate you trying all those troubleshooting tips! Because I've never heard of this issue happening before, I think you've got a calculator with a defective display or ribbon cable or display driver. How old is your calculator? You may be able to use your warranty to get it replaced.
door
Voeg je antwoord toe
hussein badawi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 777
