Ga door naar hoofdinhoud
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
84 Vragen Bekijk alle
New 3DS has no power nor power lights.
The battery has a lot of corrosion and the console wont show any signs of life even when plugged in. I am wondering, is it the battery PCB, or is it the charging port? I dont know where to start, no water damage has ever happened.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It could be the battery, i suggest maybe taking it in somewhere and see if they can replace the battery or at least get you a new one. Try taking the battery out and having a look before you take it anywhere first. Orr it could be a broken charger?
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
I bought a new charger, definitely, the PCB needs replacing AND the battery, but the console should still turn on while plugged in. The issue I'm facing is that, should the console still turn on with a broken PCB (ABXY)?
door
yeah no i dont think it'll show any life signs until it's replaced. weird you would think a new 3DS would be perfectly fine
door
@dest1ny I replaced the PCB, blue light but no screens :/
door
dang, maybe it's the screen itself? it could be cracked internally. that happened to one of my tablets once
door
Voeg je antwoord toe
RedstoneRock zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 254
