Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Vragen Bekijk alle
Phone keeps resetting after battery replacement
I recently changed my phones display and when i tried to turn it on phone kept restarting and showing 1 to 4% battery, after restarting even while it is on the charger there isnt that charging symbol next to the battery percentage in the corner. I replaced the battery but it still shows “Service” in the battery health and keeps restarting the same way like it used to on the original battery.
Update (08/07/2019)
Do you guys think this is what causes the problems with charging/rebooting?
Is dit een goede vraag?
2 opmerkingen
As you can see that's exactly the component I had marked in my answer, hence yes, that's what's causing the problems.
door
Thanks, I will take my phone to the repair shop and see what they could do
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Have a look at the small space between battery connector and the metal shield, there are a few small components that may get dislodged when prying off battery. This might be your issue, you’ll need a good light source and better some magnification too..if you see empty solder pins that is it. I enclose a picture for reference.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
The thing is, i waited for a replacement screen for about a month or so, and in that period my phone was sitting without being charged at all, so I assumed that battery just wore out or died because i didnt charge it, but installing a brand new battery didnt help so thats what is bugging me.
door
By seeing the history that is related to the SWI problem ,not connect battery properly or track is broken.
Observe carefully that you got the solution .
Score 1
1 Opmerking:
You mind explaining that SWI thingy, im quite new to this.
door
Voeg je antwoord toe
Kaid Trako zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 203
