Ga door naar hoofdinhoud
First-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
130 Vragen Bekijk alle
Checking battery health before replacement
I followed Ifixit guide to remove batteries unit from first generation apple ipad.
Is there a way how to check their health (see pics)
as I couldn’t on the ipad as completely dark and did not open, before I purchase another unit, pls?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
All you can do is test battery voltage with a multimeter or a DCPS to see if it’s still alive. Ideally voltage should be around 3.8/4.2v range if it was charged recently. As for other indepth info like number of charging cycles or possible failures, unless one has dedicated battery testing tools, battery should be up and running into a device.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Alfred Briffa zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 346
