Ga door naar hoofdinhoud
A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
216 Vragen Bekijk alle
C33uf 16 v 20% tant case b1s
Where I can buy this capicitor
Is dit een goede vraag?
3 opmerkingen
Rarely does a cap go on its own. There is often a cause are you sure you are not fixing the symptom and not the root issue here?
How about giving us some background. Apple has a few extended warranty programs for your system (I think there are five now). So before you start altering things it may make sense to see if there is an issue you can claim to get this fixed for free.
door
Thank you for your quick response
I purchased the device in late 2016 in the UAE and the machine worked wonderfully. About three months ago the device was in stand-by mode and I did not use the device for two days and when I tried to start it did not work the device. I thought the reason might be the battery and already changed the battery and the operation of the device but there was a depletion of the battery was discharged quickly to turn off the device after three days and did not work. I opened the device to see what the problem and found this piece in this way
door
Did you check to see if this was valid? 13-inch MacBook Pro (non Touch Bar) Battery Replacement Program and get it fixed under it? There was a parts issue also involved here.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Here you are: Panasonic 16TQS33MBD. Just google the code and you can get a few suppliers stocking it.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
ammar_m_ali zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 88
