Ga door naar hoofdinhoud
The 2015 version of the Samsung Galaxy A3 budget smartphone.
24 Vragen Bekijk alle
I followed repair guides to change the battery but screen frozen
I followed your repair guide to replace the battery. I assemble the phone in reverse of the repair guide, but when I switched on, the touch screen could not scroll. I tried the soft and hard reset and all suggested methods, but still while the opening screen is on and the phone is connected to wifi etc, still touch sreen is dead. Any help pls`?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Take apart your device again and see if there is any damage to the digitizer connection flex cable. If none then reassemble and be sure you sit the cable properly onto its designated fpc connector slot.
Was dit antwoord nuttig?
Voeg je antwoord toe
Alfred Briffa zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 31
