Ga door naar hoofdinhoud
MacBook Pro not turning on, no MagSafe LED
Hi everyone!
A friend of mine gave me an A1261 MacBook Pro without a battery or charger.
The Mac won’t turn on. I tried with a known good and fully charged battery from another 17”, no signs of life. The MagSafe LED (I’m using a 60W charger that works perfectly with my other 17” A1212 MacBook Pro) won’t turn on, it just flickers very dim and won’t charge the battery. Sometimes it will go blinking green or orange and I hear a slight ticking sound from the left side of the computer.
What could be the issue? I obviously already tried the SMC reset as well as the power pads on the logic board itself.
Thank you!
Update (07/28/2019)
More infos:
here’s how the MagSafe light behaves (most of the times it comes on very dim and ticks every 0.5 seconds).
The ticking comes from the area in the picture below, and you can clearly hear it both in the video and in the audio note.
I measured the voltage on the 18.5V pins of the left I/O power connector on the main logic board and I get at best 16.7V, but I can’t figure out where the problem is.
I also tried the left I/O board from an older 17” (just the power connector, the other one is different between the two Macs) and it behaves exactly the same.
Plus, heating up that section of the board makes the green light come on solid for a few tries and I get 3.3V on the “power on” pads, but still the machine won’t power on.
Audio: https://www.dropbox.com/s/dk62w3jctscg5d...
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The only ticking components I can think of are mosfets and a broken one along the charging circuit may easily prevent battery charging and the Mac from starting up. On top of that a 60W charger would be able to charge your battery but it wouldn’t provide enough power for the Mac to start up if battery is flat. An 85W charger would be needed to progress further with troubleshooting but I’m afraid it won’t make any difference with the faulty mosfet that needs to be replaced.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Ok that seems legit.
Any advice on how to diagnose them? I have the schematics for the logic board but I’m having trouble understanding how to test single components
door
@mikiotty Have a look at Louis Rossmann videos on youtube, I believe they are among the best source of information around the net and there you can get some ideas on how things work and what is involved when it comes to Macbooks troubleshooting and testing. Pointing you to " probe this" or "probe that" doesn't make much sense in my opinion considering the huge number of rails and components on a board.
door
Voeg je antwoord toe
Michele Ottaviani zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 14
Altijd: 311
