Ga door naar hoofdinhoud
The Hoover LiNX is a cordless vacuum cleaner. The vacuum uses interchangeable fade-free lithium-ion batteries that allows this device to be used everywhere and on multiple floor types. The Hoover LiNX uses Hoovers WindTunnel® 3 Technology which uses three channels for suction to suck up debris.
4 Vragen Bekijk alle
Why is my vacuum not picking up dirt? Brush is spinning ok.
Why is my vacuum not picking up dirt? The brush seems to be turning ok.
Is dit een goede vraag?
Score 2
1 Opmerking
because the tube from the head to the trap if full of "stuff" I came to this forum hoping to figure out how to take it apart and empty it.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Most probably a loss of suction:
See this video on how to get it to suck.
https://www.google.com/search?client=saf...
Was dit antwoord nuttig?
Score 2
Good afternoon,
I'm having a similar issue. I've taken it apart and cleaned it. No blockages. The roller spins on max power mode. However, I get no power on regular mode (first switch). No suction. I believe I should get be getting suction from here?? Thanks for any help in advance!
Voeg je antwoord toe
Trish Frank zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 20
Altijd: 823
