Not booting up Battery is at 2.4V should be 3.82V
How can I bootup bypassing battery to check before having to buy a new battery?
Is dit een goede vraag?
There must be a battery installed for the device to boot. You’re battery voltage is too low but the charge circuit should still recognize it and charge it, allowing for a boot process once the battery gets to the proper voltage. Leave the device charged overnight to see if this helps.
If the battery is not charging properly, it could be a battery issue or a charge circuit issue. I would do the following (in order):
Was dit antwoord nuttig?
Thank you for a very well thought out testing process. will try the troubleshooting described and let you know the outcome.
Good luck...let us know how it works out or if you have any additional questions.
@refectio replaced battery ammeter .43 Amp phone was on DFU mode. Selected restore and upgrade after message (preparing phone for restore) phone displayed Apple logo, iTunes displayed (serial number: n/a) then a popup (unknow error occur(9)).new battery got warm and now ammeter is at 0.00 Amps old battery is drawing 0.01 Amps like before. Any suggestions ?
Error 9 is typically NAND related. Check the two NAND lines from the PMIC. If they are good, then the NAND may need to be reprogrammed or replaced.
The two NAND lines are PP0V9_NAND & PP3V0_NAND. You can find the schematics by searching online - "iPhone 7 Plus Schematic" - (we can't share them here). As for programming the NAND metadata, you need an expensive and specialized programmer...this is not a DIY kind of thing.
The battery shield should have no impact if the battery is securely connected.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 141
