Ga door naar hoofdinhoud
Not charging when plugged in
Plug turns green, orange then fades to blank in quick succession once plugged in. Not charging.
For the past month or so the charger has intermittently not charged when initially plugged in but would light up and charge after reinsertion.
Not sure if i have a 1.33ghz or a 1.2ghz
(laptop doesn't have enough power to come out of sleep now)
Charger is the original purchased w/ computer in late 04.
45W model# A1036
Battery was still holding a charge for several hours before charger failure
Is dit een goede vraag?
Score -1
1 Opmerking
Thanks for your help, was able to get an after market charger and it did the trick
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
To see which machine you have remove the battery and look on the side walls of the battery compartment. I believe the 12" was the 1.2 GHz and the 14" was the 1.33 GHz. Your problem could be the AC adapter or the DC-IN port. By your description I would guess the Adapter.
Here's a variety of original and knock off adapters:
http://www.google.com/search?client=safa...
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
clay zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 738
