Ga door naar hoofdinhoud
MITSUBISHI WD-73C9 rear projection dlp HDTV
25 Vragen Bekijk alle
Replaced Lamp TV shuts down still?
I’m having a problem with my Mitsubishi Lamp replacement, I did a replacement for the Lamp and it went completely smooth nothing broken just the lamp. I did a hard reset and when the tv turns on it stays on for about 30-40 seconds and then shuts down. The Tv also provides me with the 34 error code that the Lamp is bad but I had just replaced it, not also did I replaced it but I cleaned out the dust using an air can and is as clean as could be. Very confused, any ideas??
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
I have this problem and I see nobody answered you in 2 yrs. Did you ever find the answer?
Was dit antwoord nuttig?
Voeg je antwoord toe
Luis Esquivel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 29
