Is iPod touch 7 gen replacement screen same as 6th generation
does the 7th gen ipod touch use the same screen-digitizer as 6th gen ipod touch
Is dit een goede vraag?
They might look the same and the same size but they are not the old regime what's a 9.7 size screen in the newer gen has a 10.2 screen so they're a little different little bigger than the old one they do that so if in your situation it breaks you can either buy a new one or a new screen for the same size so I would suggest to get a new 10.2 screen
Was dit antwoord nuttig?
This sounds like an iPad answer, not iPod touch.
Hi
its working fine with me, just changed 7th damage LCD screen with iPod 5/6 generation LCD screen, display and touch working good!
Cheers
I just used an OEM refurb 5/6th gen screen on one and it works perfectly. Not sure if aftermarket is the same.
No, it will not work.
it works .The 5th gen without back camera might have a hard time fitting in but it works
guys I really need help so if you guys could see my question it would be helpful
btw good luck with your ipod
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 33
Altijd: 3,813
