How to check fluid level on transmission
2013 how too check transmission fluid
Is dit een goede vraag?
You cannot check or add fluid as described there is no dipstick that you can just grab and check fluid! You have to get under the car and remove an engine mount to get to the dipstick which bolted in with 12mm bolt ! It is a poorly designed transmission with no fill tube for easy access. $250-$400 for transmission service!
Was dit antwoord nuttig?
You literally remove 1 7/16 bold plug my guy.
Thus engine and transmission is GMs' most defective ever
Transmission Fluid Level Check Chevrolet Equinox (2010-2017)
There is no DIPSTICK on the 2011 Chev Equinox!!
^^this^ and this answer should be removed
You couldn't be much more wrong than you are.
You have to remove 3-4 bolts off of the cover underneath the car. You cannot access your dipstick without removing that cover and will have to have it on a lift to get an accurate reading of the fluid level. Look for the full video on YouTube. ”How to service Chevy Equinox transmission fluid by Santer Auto Repair LLC.
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 104
Afgelopen 30 dagen: 682
Altijd: 35,985
2 opmerkingen
Where is transmission dip stick located
door Howard Prigg
There's no dipstick,under the car, there's a bolt, a lady can't get to that,but I myself watched my dad,I can't afford 400 to a mechanic. I'm going to do it.ty to those who showed me on here.
door Juanita Aldape
