Ga door naar hoofdinhoud
Reparatie-informatie, servicehandleidingen en hulp bij probleemoplossing voor koelkasten van KitchenAid.
Kitchenaid ice maker does not work
Hello, I have a 2015 Kitchenaid french door bottom freezer refrigerator. Water inside the door, ice maker in the freezer. Model KRFF202ESS00 S/N K51819876. The ice maker stopped making ice. I noticed the door water (we don’t use this feature) volume was low so replaced the filter and corrected that problem, but still no ice. The ice maker appears to be going through the motions, but no water is getting into the ice maker. Checked the turn on valve - no leaks, water is on. There is no water in the tube in the back of fridge. Looking for ideas to avoid the repair cost. Thanks
Is dit een goede vraag?
Score 2
2 opmerkingen
correction on the model number! KRFF302ESS00
door
If all water issues are working and no ice, it is because the freezer is not cold enough. I had this problem and tech came out to move the sensor. This helped for a few months, but problem started again...no ice. I removed the drawers and back panel to get to the evaporator in the back of the freezer. A large block of ice was in the space and the evap was iced up. After thawing, i filled the space to the right of the evap where the refrig lines enter to stop moist air from collecting and making ice.. This has solved all my issues and now my freezer is staying 5F and refrig is 34. Ice making working again.
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Of course when the arm is up, it thinks the ice bin is full and stops making ice. But the real problem is most likely the:
Water Inlet Valve
The water inlet valve is an electrically-controlled valve that opens to supply water to the dispenser and ice maker. If the water inlet valve is defective, or if it has insufficient pressure, it won’t allow water to flow through. As a result, the ice maker won’t make ice. The valve requires at least 20 psi to function properly. Make sure that the water pressure to the valve is at least 20 psi. If the water pressure is sufficient, use a multimeter to check for power to the water inlet valve. If the water inlet valve has sufficient pressure and is getting power, but the ice maker won’t fill with water to make ice, replace the water inlet valve.
Low Water Pressure from House Supply
The home may have insufficient water pressure. The water inlet valve supplies water to the ice and water dispenser. The water inlet valve requires a minimum of 20 psi to function properly. Check the water flow and test the pressure to determine if it is at least 20 psi.
Door Switch
The door switch turns off the ice and water dispenser when the refrigerator door is open. If the door switch fails, the dispenser will not turn on. To determine if the door switch is defective, use a multimeter to test it for continuity. If the door switch does not have continuity when activated, replace it.
Was dit antwoord nuttig?
Score 4
6 opmerkingen:
What about if your water inlet valve has been replaced and still no water to ice maker but water to filter is fine? Is there a way of checking to see if the power to inlet valve portion of the ice maker is not getting power?
door
Check the next two solutions.
door
I did both and sadly no luck. I can only think that the solenoid/terminal wiring connecting to the water inlet valve that feeds the ice maker needs to be replaced.
door
Where are the next 2 solutions? I see 0 solutions.
door
It sounds like the ice maker is cycling but just not getting any water, and on this KitchenAid model that’s often caused by the fill tube freezing up. When the small tube that feeds the ice maker gets iced over, the machine goes through all the motions but never fills. A simple test is to unplug the fridge for a couple of hours and leave the freezer door open to defrost that area. You can also check the fill tube at the top rear of the freezer and warm it gently with a hair dryer on low if it’s frozen solid. Also make sure the freezer is actually getting down to around 0–10°F, because the ice maker won’t call for water if it’s too warm. If none of that helps, the water inlet valve might be weak and not opening for the ice maker even though the door water works. Usually, though, a frozen fill tube is the culprit.
door
1 commentaar meer tonen
In my case, the ice maker and the internal water dispenser stopped working.
It turned out that the filter had frozen.
Once defrosted and re-installed, everything working again...
Yeah, why'd that freeze? Something to fix again soon!
1 Opmerking:
Hi @pompey67
What's the model number of the refrigerator?
door
Voeg je antwoord toe
Amy Sullivam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 65
Afgelopen 30 dagen: 356
Altijd: 54,400
