Ga door naar hoofdinhoud
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
774 Vragen Bekijk alle
How to save file from died MacBook Pro retina 2015
hello everyone, I have a MacBook Pro 15" Retina Display Mid 2015 that has died because the logic board error and Apple service told me to replace the logic board and top case which cost 1400 usd. i dont hace money for this repair. is there a way how to save file from that died macbook? sorry for my terrible english
regards
Is dit een goede vraag?
1 Opmerking
You may as well look for an indipendent lab performing component level repairs, better if experienced with Macs. A typical repair would cost you something in the range of 200/400$
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Macbook Pro 2015 allows removing ssd from the board. So there are 2 ways to back up your data
Method 1: Stick your ssd hard drive into another supported macbook pro and copy the data
Method 2: Use a reader that supports PCLe SSD port
Was dit antwoord nuttig?
2 opmerkingen:
SPAM removed.
door
thank you Tuấn Nguyễn. will try it
door
Het nuttigste antwoord
You’ll need an OWC Envoy Pro enclosure. Sell it on eBay after your recovery
https://eshop.macsales.com/item/OWC/MAU3...
Score 3
1 Opmerking:
thank you @mayer will buy it
door
Voeg je antwoord toe
Darren Stone zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 103
