Ga door naar hoofdinhoud
Released June 2017, the iPad Pro 10.5" replaces the 2016 iPad Pro 9.7".
145 Vragen Bekijk alle
Which size of Tesa 61395 tape should be used for the home button?
On the screen replacement guide (iPad Pro 10.5" Screen Replacement), the guide states on step 19 to use a double sided tape, which is the Tesa 61395 tape (Tesa 61395 Tape ). The problem is that there is four sizes of that tape. Which size is used in step 19, and which size should I use, 1 mm, 2 mm, 4 mm, or 8 mm?
Tesa 61395 Tape Afbeelding
Product
Tesa 61395 Tape
$5.99
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Step 19 is sticking the home button down u would just use the widest u can and trim off the excess or use more thinner ones next to each other, which ever u have or whichever is easiest for u, ur just trying to stick the bracket down...
Was dit antwoord nuttig?
Score 1
I find 1mm too narrow and 2mm a little bit wide to use on home button, since there’s no 1.5mm available - use 2mm and cut out the excess.
Score 1
Voeg je antwoord toe
Cody zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 698
