Ga door naar hoofdinhoud
Instructies, begrijpbaar door een machine, die computerprocessoren aansturen om foto's van katten op het internet te tonen.
209 Vragen Bekijk alle
How can I erase this drive?
I am trying to erase the drive on my 2006 MacBook so I can sell the machine for parts, since it's good for parts but has multiple issues and addressing it quickly hits my no repair threshold. I have tried multiple tools with persistent failure. It needs a battery, optical drive (weak motor but can be made to listen by forcing the matter while ejecting okay) and motherboard check (Significant wattage loss as it charges; didn’t see on my 2011 13”), which is why I am going to be selling it as-is.
  • Parted Magic (kernel panic)
  • DBAN (F10 nonfunctional)
  • PC Disk Eraser (Parted magic based) ( Kernel panic)
  • HDDErase 4.0 (Not recognized)
  • Disk Utility (High Sierra) (Failed to remont the drive)
  • Active KILLDISK (Results pending)
Since I have not had much luck and would like to include the drive for a better AS-IS price (without an OS for licensing avoidance problems on a junk machine), what methods are known to work with Macs?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Active KILLDISK worked to wipe the drive. One pass only so do a 3 pass you need to do it 3 times. Not ideal outside of one off cases.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Nick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 68
