Ga door naar hoofdinhoud
The PowerBook 170 was released by Apple Inc. in 1991 along with the PowerBook 100 and the PowerBook 140. Identical in form factor to the 140, it was the high end of the original PowerBook line featuring a faster 25 MHz Motorola 68030 processor with Floating point unit (FPU) and a more expensive and significantly better quality 10 in (250 mm) active matrix display. It was replaced by the PowerBook 180 in 1992.
5 Vragen Bekijk alle
How do I connect a external display to a PowerBook 170?
Do I use the HDI-30 port?
Is dit een goede vraag?
Score 1
1 Opmerking
Your systems specs: PowerBook 160
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Sadly, you’re between a rock and a hard place ;-{
Apple never offered external monitor support for the older B&W displayed Powerbooks. There was a company that made a SCSI (HDI-30) to composite video device but it was a flop!
Here’s your systems ports
Apple updated the 160 with color with the intro of the 165 which offered a Mini-15 display interface. I don’t think you can find the needed cable for it.
And here’s the 165c ports
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
@danj I found them (but it's a hard find), but I made a mistake and assumed it supports it like the 170/180. The Vid14 cable is sold under M3927LL/A. I'm not surprised it flopped since composite is less then ideal, but that was it outside of not having a second display.
I did some research on it, and Apple had FCC compliance issues at the time more then once. They had to recall the Apple III because they had trouble with the original. It's more of an issue on the desktops then portables.
door
@nick - This is the correct cable its Mini-15 to DB15 which can then plug in a VGA adapter Video Cable. Back then NEC & Sony where using the DB15 connector which predates the VGA standard.
The composite video adapter was by a 3rd party not Apple!
I don't know where you got the idea Apple had FCC issues I never heard of any for the PowerBook's. I had both a 165c and a 180 and never had any problems.
The Apple III was a flop for many reasons. Frankly, I used an Apple II at the time and just didn't see the benefit of upgrading.
door
Voeg je antwoord toe
Owen Ready zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 627
