Ga door naar hoofdinhoud
Released by Samsung in March 2016. Model SM-G930.
425 Vragen Bekijk alle
Weak wifi signal after battery change
Hello. I changed the battery on my S7 & since then I have experienced a very weak wifi connection. I can no longer connect to the wifi in different rooms of my home. I have looked at the wifi antenna & everything looks fine. I did accidently pierce the old battery when I was taking it out & it got  very hot before I was able to remove it.  Any idea?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
317/5000
Hi Guys, I also have the same problem, I changed the battery of my S7, and the signal of my wifi has decreased dramatically, I have verified that everything is connected correctly, and I couldnt solve this problem, T Burrows if you found Any solution please help me, I’ll be very grateful.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I am still experiencing the problem. I was wondering if it is a problem with the battery?
door
You’ve detatched the wifi antenna lead from the motherboard. The antenna is built into the top (black/brown) plastic shroud on the S7. You’ll have to open the phone again, and make sure it has no signs of damage, and is properly attached to the logic board.
Voeg je antwoord toe
T Burrows zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 570
