Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Vragen Bekijk alle
MacBook wont do anything!
Through a series of unlucky events in ended up resting my macbook on the car on my way inside. I fell asleep lastnight and as I woke I came outside for some fresh air only to be greeted by my macbook. It did not appear to be wet and the lid was closed. I immediately took it inside and tried to power it on but I got nothing. I plugged in the charger and the indicator on the magsafe tip wouldnt even light up. Ive tried (2) different charger in different outlets. The magsafe now seems to light up dimly but it doesnt seem that the laptop is getting charged
sn. This device previously suffered from water damage. A drink was soulled on it in the studio a few years back laptop went dead and I bought a desktop mac. After about a year I tried to power it on and surprisingly it worked. The only thing thats was messed up was the keyboard butI replaced it and then I upgraded to a SSD (samsung 860 evo) device was working flawlessly up until now.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Right now I could let a Macbook sit outside at open air for a week without any issue and I presume the same would apply to other thousand places on earth. I’d think there are thousand others where a Mac at night would get soaking wet. The fact you had liquid damage in the past is the key here, as if you didn’t properly decontaminate the board at the time of the spill you might have had corrosion and oxide in progress since then and some condensation might have added the proverbial drop to a full jar. Faint green light points to a logic board issue at first power stage. You may try this and see if that helps:
MacBook water damage - The definitive guide
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Glenn David zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 37
