Ga door naar hoofdinhoud
Uitgebracht in 1999, opvolger van de originele PowerMac G3, 300-450 MHz, 64 of 128 MB RAM, 6 of 12 GB HDD
won't power on
Hello!
I am also having the same problem. I did what u suggested and nothing. I opened the computer and I noticed that 1 of the plugs P5 was not connected to anything. My question is should that part be connected and if so where? Maybe that is what is causing my G3 not to power up?
Thank you.
Edie
Is dit een goede vraag?
1 Opmerking
Please start a new question as this one has been answered and almost no one will now look at it. Thanks
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
The Plug "P5" is just another 4-Pin Molex power connector. It is used to power a secondary hard drive, and doesn't need to be connected to anything for the computer to work. If the computer isn't powering on, a bad power supply may be to blame. The PowerMac G3 Blue and White (as opposed to newer/older powermacs) uses a standard PC "ATX" power supply. You can buy these at just about any store that sells PC parts, or use an existing one if you happen to have one handy.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
edith zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 22
Altijd: 1,527
