Ga door naar hoofdinhoud
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Vragen Bekijk alle
How long will my battery last?
*CoconutBattery data*
While I am not giving up on this notebook over the battery as I can replace it when things get worse (and it’s in the pipeline after I address the hard drive cable and thermal paste anyway), I am wondering how long I should expect the battery to last before it fails. I have posted CocunutBattery data and have confirmed it’s a Dynapack battery, so I do believe it is aftermarket based on that alone. I have tried calibrating it 2 times and it keeps coming back, so I am leaning towards the pack using a cheaper BMS that doesn’t handle calibration properly.
While I do plan on replacing it as soon as possible, how long should I expect the battery to hold a charge before it fails? I checked it for expansion and it doesn’t show any signs of that issue, so the battery is otherwise in good shape. What I’m doing on my end to extend what life is left is I am charging it when it hits 30% charge if at all possible, so I can get some extra time out of it before I need to replace it.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
That appears to be your original battery. Check the manufacture dates. Usually the batteries date is within the prior month of the machines date. Which yours is.
Machine 12-05-11
Battery 11-14-11
Was dit antwoord nuttig?
Score 3
1 Opmerking:
The box the machine came with said swollen battery, which mine was not. At this point, I think they reused an old box they had around to ship it and didn't take that off. The reason I thought it was aftermarket since most of the '11-'12 machines are old enough aftermarkets show up in them a fair bit. I don't understand why you wouldn't cross that out or scratch it out so you can't tell.
Anyway, yeah - that's why I checked. It was more so I have closure on the matter since I wasn't entirely sure if it was true or not. It sounds like I have time to shop around if the battery is original to the system with such a good capacity.
door
Voeg je antwoord toe
Nick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 203
