Outlet plate for Bendix S4LN magneto
I have a S4LN Bendix Mag off an I0-360 A1B . Wanting to put on new Kelly ignition harness but the outlet plate is original and will not accept the male threads that are supplied with new harness. Where could I get a couple of outlet plates that will work?
Thanks
Stan Soloduka
Midland Ontario Canada
ssoloduka@gmail.com
941 416 9291
Is dit een goede vraag?
1 Opmerking:
Hi Stan.
I’ve just seen this entry and I notice the date is June 2019. I assume you’ve found the answer by now but if not, can I suggest you supply some more images of the parts in question and I'll look further for you.
Regards…Geoff
door Deel
Voeg een opmerking toe
