Is this a Tristar issue?
So looked at an iphone 7 for a friend the other evening, came to me completely flat and not charging, initial look in the charging port showed obvious physical damage and 2 pins missing, my guess is he was trying to clean lint/fluff out of the charging port rather aggressively.
First port of call was to replace the charging port and upon completion the phone will indeed now power up, however as soon as it powers up it then sits there on 1% battery and wont charge, the phone will not go into DFU mode and is not recognised by itunes when plugged into a PC.
A USB ammeter shows that the phone draws a whopping 0.08amps when plugged in so as expected it does not charge. Does the above sound like a Tristar failure?
My current thought is that there was initially a fault with tristar or tigris resulting in no charge that caused my friend to aggressively attack the charging port and break it.
If this does sound like Tristar then any tips for a first timer in replacing it? I’ve not done any hot air work before though am reasonably handy with a soldering iron on normal sized stuff. Fro what I can make out you use a reasonable amount of flux and the rest is patience
Is dit een goede vraag?
