Ga door naar hoofdinhoud
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1366 Vragen Bekijk alle
iPhone 7 Plus stop charging at 3% after replacing new battery.
My iPhone 7 Plus battery just got replaced with the new one. I forgot to put ‘sticker’ to prevent the battery from moving. after few months the old battery stoped working, I even cannot charge it at all.
After that I replaced it with a new one. It stop charging at 3%.
I opened battery setting, it didnt show at all about battery capacity.
And then I also tried 3uTools, and I cant read the capacity too.
Anyone have a solution?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
There are some tiny components surrounding the battery connector. One of them allows the battery charge state to communicate with the CPU/Charge Circuit. It’s not uncommon to accidentally dislodge components when disconnecting the battery and this is a typical “pry damage” symptom.
Look for R2201 in the image below.
Was dit antwoord nuttig?
Score 3
4 opmerkingen:
How should I fix this?
Are you suggesting me to buy a new dock connector replacement?
door
No, you need to determine if the highlighted component is still there. If it's missing, it must be replaced which would require a micro-soldering repair.
door
Hi, I didnt quite understand what is actually "battery connector". I looked at the battery connector on the flex cable and in the motherboard, on my eyes the diagram given is not matching with the one I see. SO maybe I looked at the wrong one
door
FYI: I got a replacement batt, now it charges only till 13%
and then it wont charge againt till it droped 1% and the phone restart by itself
door
Have you tried other new battery? maybe the battery you replaced was faulty.
2 opmerkingen:
No, I havent. I will send it back to the seller today. I hope its the battery
door
Just try to test your old battery if that charge more than the percent you need, if that goes up means you got a faulty batt.
door
Voeg je antwoord toe
Henka Gonzalez zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 317
