Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De vierde generatie Hyundai Elantra werd in 2006 uitgebracht voor het modeljaar 2007. De Hyundai Elantra werd op de Zuid-Koreaanse thuismarkt verkocht onder de naam Hyundai Avante.
Horn blows intermittently with vehicle parked and off.
The horn on my 2010 Hyundai Elantra GLS goes off intermittently when parked and not running. It always blows 18 times, stops for about 5 seconds, then blows another 18 times. I can push the lock or unlock button on the key fob and it will stop, but will start again on it's own, for no obvious reasons. I changed the batteries in the key fob but that didn’t help. The TPMS light is also on solid, but I think that is a different problem as the light was not on when this issue started. I can pull the horn fuse and of course it will not go off. Any ideas would be appreciated.
Thanks!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Gekozen oplossing
Use your key (not the fob) to lock then unlock the driver side door to turn off your security alarm.
Was dit antwoord nuttig?
Score 1
Mine did the same thing when I disconnected the positive(I believe) terminal from battery. After some research what I gathered was there used to be a remote start installed and it’s just the remnants of it or something. I tapped the brake and it stopped.
Thanks for the reply. Finally went to the dealer who removed an additional anti-theft system the previous owner had installed which was not playing nicely with Mazda's built in system and it's fine now.
Voeg je antwoord toe
veteransnewstoday zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 33
Altijd: 7,519
