Ga door naar hoofdinhoud
De Nintendo Switch is een draagbare spelconsole die via een dockingstation op de tv of onderweg kan worden gespeeld. Uitgebracht op 3 maart 2017.
705 Vragen Bekijk alle
Game will not insert into switch
I took out Splatoon 2 to play Mario kart then Mario kart would not go in. I tried all the others games now hey would not go in either. I blew on the switch and cleaned it outs and made sure I was putting them in right they still would not go in
Update (06/12/2019)
I really need help!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
A piece of fluff was stuck to the inside carefully shaking the switch worked! Thank u!
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Glad to hear you figured it out!
door
Het nuttigste antwoord
It sounds like there may be something blocking you from inserting the games. Use a flashlight to look inside the slot to make sure something did not get lodged that would block putting the game in. Check the back of Splatoon 2 to see if there is any missing pieces that might have came loose. Another possibility is that one of the pins that reads the game cartridges may be out of place. Let us know what you find.
Score 3
Voeg je antwoord toe
Ur mother zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 68
