Ga door naar hoofdinhoud
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
20 Vragen Bekijk alle
Why I cant find wifi networks?
I have my laptop running Windows 10 Home, my laptop abruptly stop recognizing wifi networks I have 2 routers and none of them cant find it, it find the wifi network only if it is extremely near to the router, Im trying to update the driver I downloaded it from here: https://www.asus.com/Laptops/X555LB/Help...
I followed this steps to install it: Step by step
1. Extract the drivers package and get into the folder
2. Click the File option from the upper left corner of the driver package folder
3. Move the cursor to the Open Windows PowerShell option
4. Select Open Windows PowerShell as administrator option
5. Select Yes, Allow this app to make changes to your device.
6. Input .\Install.bat
7. Press Enter key to start drivers installation until return to next command line.
8. After install successfully, please restart.
But after that the driver doesnt change, also in the device manager the card appear without any sign of problem.
Could be the wifi card?
How I can fix it?
Thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi Jose,
As you have said
“…wifi network only if it is extremely near to the router ..”
it sounds like the antenna is not connected.
Check this:
How do I remove the wifi card?
Let us know how it goes.
Was dit antwoord nuttig?
Score 4
1 Opmerking:
Thank you, that solved my problem
door
Voeg je antwoord toe
Jose zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 699
