Ga door naar hoofdinhoud
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 Vragen Bekijk alle
iPad looping in recovery mode and ending with error 4005
iPad not used for a little while so obviously missed out on updates, so cannot start it up. The device charges ok but loops on the Apple logo. Is recognised in iTunes in recovery mode, but recovery does not complete, ending with error code 4005. I have managed to update the iPad using a workaround, but the device won’t start up.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Error 4005 on the iPad is usually caused by a corrupted NAND. This can be repaired but it does require a micro-soldering repair.
Was dit antwoord nuttig?
Score 4
Best way is to restore iPad with iTunes as iTunes can detect it. You have latest ios version on iPad. Before this try to update iPad. Update will not delete data on iPad. Restore iPad will erase all data on iPad.
Voeg je antwoord toe
Janis Haswell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 250
