Ga door naar hoofdinhoud
Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
Screen flicker after microsoft logo then goes black.
was doing a battery replacement and after i got the screen off i wanted to check everything was ok so i booted it up and it would post the microsoft logo, then flicker some little white squares above the logo in a line. then goes black. Hooked up to a monitor with the mini display port and its running fine on there. does this mean the screen is broken, even tho it still shows the logo for a sec?
Update (06/05/2019)
also the touch screen even works when its a black screen, i can see my fingers interacting with stuff on the monitor hooked up through mini display port
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If the screen still exhibits some functionality, then perhaps it wasn’t re-attached properly? Try carefully re-attaching it one more time to see if there’s a difference.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
yes I have several times. no luck.
door
what do you think the odds are that its something in the display compared to the main board? I am thinking about ordering a new display but I dont wanna waste my money.
door
If you hooked up a monitor to the mini Display port and it worked fine from there, then most likely the problem is the display on the Surface Pro and not the motherboard.
door
ok, thanks for your help Dan.
door
Voeg je antwoord toe
Blake zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 505
